-   Volvo S60 & V60 (https://volvoforums.com/forum/volvo-s60-v60-10/)
-   -   What do you call these and where can I find some new ones ? (https://volvoforums.com/forum/volvo-s60-v60-10/what-do-you-call-these-where-can-i-find-some-new-ones-66951/)
Derdertim Nov 13, 2012 05:18 PM
Ok so video# 1 of may to come. Please watch the video and let me know if u can help
Thanks -Tim R.
Derdertim Nov 13, 2012 05:19 PM
01_fast_ride Nov 15, 2012 05:57 PM
Hi Tim,
To say that you have a problem is an understatement. Those don't look like stock parts. When you did the struts yourself, did you save any of the original pieces or was it pretty much like that before you started?
The sleeves that you show look like remnants of the old spring seats. The spring seat is that hard rubber black part. When you get serious failure of that part the steel tube will separate from the rubber and your suspension will feel squishy and knock a lot from the movement. Did you replace the spring seats when you did your struts. If the sleeves are from the spring seats and you put them back in with that kind of damage, that is your problem right there. Order new spring seats immediately.
JRL Nov 23, 2012 12:36 PM
You NEVER, EVER replace struts without replacing the spring seats (That's what these strut mount rubbers are called)
You only use either OEM Volvo XC90 spring seats or IPD HD spring seats, all others are junk
Derdertim Nov 26, 2012 03:58 PM
Ok..
Ok I ordered new spring seats, now where do I get to rubber peices that go on top of the frame around the strut refer to the first half The video).
01_fast_ride Nov 28, 2012 04:27 PM
Here's a diagram of the parts
Check with them. Or try the dealer.
http://www.autopartsapi.com/eEuropar...c8aa0980a1.GIF
