where can i find ????
I have a 04 volvo s60 recently purchased under 60k, I found out that the car was in a little accident involving the rear passenger wheel, must have slid into the curb or something, i had a punch of parts replaced on the car some including starting with the rear passenger side: lower control arm, wheel bearing, all new rotors, control arm bushings, new brakes. Reason for lot of work done on the right rear due to tension in the area causing squicky noises, when the car was jacked up the tire was on an slant and also the tire has been moved back a cple mm. Now that theses parts have been changed the alignment is off. So i cant get an alignment done becuase the rear passenger tires is still moved back. I took it to a frame shop they said everything was ok but i either needed a top control arm or another part which is around 800 dollars. I was wondering if anyone know a site something like at the dealer where they can print off a picture diagram say or the rear control arm area, it shows all the different parts connecting and usually has the different partsnumber for each ?
RE: where can i find ????
ok so i have to get the rear right side hub assembly replaced and the upper control arm hub is going to run me $815 and the contol arm 293 anyone know where i could possibly get them cheaper then the dealer?
Stop, I don't really know what is going on with your car but it sounds like you are being taken for a ride.
Can you be more exact on what parts were replaced? |
Try a salvage yard.
If you go to Alldatadiy.com, you can get the diagrams you want and a lot more for an annual fee( @$20). I have used it for all my cars and it allows me more control when buying parts (especially online) and it tells youhow to fix it step by step. Hope this helps
Try to browse other sites that sells discount auto parts. You can also get some discounts if you buy several products at the same time like control arms, brakes, etc.
