1998 s70 ABS, Check engine, flashing Arrow ??
#21
RE: 1998 s70 ABS, Check engine, flashing Arrow ??
TPS code first, then O2 sensor bank 1 sensor 1..
I may have to wait until the tester gets here to recheck. The Tech said TPS, then O2...
I replaced the air filter, and bought some fuel injector snake oil (lucas) and was thinking about running seafoam through the vacuum lines.. Don't want to damage anything so I will wait on that though..
#24
TECH- Thanks so much for your help first off.....
Couple developments, I inspected the ABS module today and all the soldiering looks fine, The unit is remanufactured and looks like new... ALTHOUGH while sifting through paperwork I noticed that 4 weeks ago the brake pads were replaced along with the Rotors were replaced.. How do you diagnose a damaged sensor?? From reading the sensors can become damaged during brake work correct?
Thanks again..
Thanks again..
#25
#29
Great! I used a TPS out of a 1997 Turbo 850 and the part # was exactly the same. I put the TPS in my s70 and cleared the codes. The Check engine light went off for about 40 minutes but came back on. I read the codes again with my handy dandy reader- ONLy 1 code now.
02 sensor- Low volts bank 1 sensor 1.
I pulled a sensor off a 1995 N/A 850 in the hopes it may function. I may put it on tomorrow to see if it makes the 02 code dissapear...
What would cause low voltage to the 02?
#33
They had 2 turbo 850's and 2 N/A's.. One Turbo was in great shape, I couldn't believe that that the car was there, it looked great.. I wonder if the engine had given out...
Any other bits I should be pulling off these cars at rock bottom prices? I figure i'd rather have a box of spares..... Especially at $3.00 a sensor.
#39
