1998 S70 Engine Compatability
Good day all,
I'm looking into an S70 with VIN#YV1LS5544W1471226, this seems to be pointing me in the direction of a B21E Motor. If that is true, what motors/years can I use to swap out the long block on this car? It has a blown head gasket and I'm not comfortable with how it was operated or I'd just replace the gasket. I'd prefer to find a donor motor and need to know what my options are without doing any mods to the existing vehicle. Thanks!! NIck:D:D:D |
your VIN says you have the B5254S engine. That's the naturally aspirated 2.5L 5 cylinder. Other models with this would be the 96/97 850s (base, not turbo'd) and the 98-99 S/V/C70s again with the base NA engine. Should be really easy to find - check out car-parts.com for recycle yards near you.
Sweet, thank you very much!!
You can't use a 99. It went to coil on plug and electronic throttle.
