1998 S70 Not starting
Old 10-17-2017, 05:52 PM
jpirish's Avatar
Default 1998 S70 Not starting
It started with the car just stalling while driving. I replaced the fuel pump relay 2 times and it started right back up. 3rd time it stalled nothing worked .Time to get a tow home. The only way I can get 12 volts
on the fuel pump connector is to run a jump wire strait from the battery to # 87 on the pin were the fuel pump relay goes. I tried jumping #15 & #87. I get no 12 volts at the plug for the fuel pump. I changed the fuel pump and the throttle body sensor & the air control valve also. Also ignition switch assembly.
Help
jpirish
91 240 173K
2 98 XC
1 98 S70
Old 10-18-2017, 07:46 AM
Psaboic's Avatar
Sounds like it could be a wiring issue. Most likely from the ignition switch to pin 87 on the pump relay. One thing you could try is remove the computer module and reseat it. Probably won't fix the issue, but definitely worth a shot.
Old 10-19-2017, 05:45 PM
jpirish's Avatar
Default Got IT :)
Changed ignition switch again . Bang pump worked. Junk Yard Parts 10.00
Thanks
Jpirish
Old 10-20-2017, 09:01 PM
Psaboic's Avatar
Well, I was close <grin> Glad you fixed it!!
yanhor15
04-27-2015 01:44 PM
delsa
03-21-2008 11:35 AM
redlight
03-06-2008 05:23 AM
starfighter
08-01-2005 02:47 PM
Quick Reply: 1998 S70 Not starting
