1998 volvo s70 t5 misfire
Old Apr 13, 2020 | 09:41 PM
FromTheFar's Avatar
Default 1998 volvo s70 t5 misfire
Hello, i have a 1998 volvo s70 t5M with a misfire. All parts replaced/modifications listed below and have been installed within 2k miles ! Codes for check engine are
P0300
P0301
P0302
P0303
P0304
P0102 (maf was unplugged)
P0340 (checked the sensor, looks fine)
Car misfires on idle, will stall on idle, and will not go 1 block without jerking horribly or dying! There is also a gasoline smell!
Any suggestions help! Thank you
Parts replaced/ modifications:
Ipd intake
Ipd tcv
Snabb intake pipe
New maf sensor
New acceleration sensor
New spark plugs (gapped .28)
Ipd wires
New cap and rotor
Msd ingnition coil
Air pump delete (No cel)
New pcv system with new lines and sensor cleaned at intake pipe
New gas cap
Cleaned IAC valve
New vaccum lines for TCV
New purge valve
New evap valve
New intake manifold gasket
Timing belt done
New fuel pump
New fuel filter
New O2 sensors
New fuel pump relay
Muffler delete
Old Apr 13, 2020 | 10:50 PM
Psaboic's Avatar
P0300
P0301
P0302
P0303
P0304
Ipd intake
Ipd tcv
Snabb intake pipe
New maf sensor
Ipd wires
New cap and rotor
Msd ingnition coil
New gas cap
Cleaned IAC valve
New purge valve
New evap valve
Timing belt done
New fuel pump
New fuel filter
New O2 sensors
New fuel pump relay
Muffler delete
Well, according to my code reader manual. P0300 is a multiple cylinder misfire, P0301 is cylinder 1 misfire, P0302 is cylinder 2 misfire, P0303 is cylinder 3 misfire, and P0304 is cylinder 4 misfire. So the only cylinder not misfiring is cylinder 5. With so many cylinders misfiring, it is doubtful that the spark plugs are bad, but if they are not NGK, or Volvo OEM, I have found that our cars did not like them and we had problems. That said, I am leaning toward a common item causing the problem. Check for a vacuum leak, a loose/split turbo to throttle body hose, loose connector to IAC, or other sensor. If it is a bad part my guess is a bad/weak coil, bad distributor cap or rotor, or bad plug wires.
Old Apr 14, 2020 | 02:08 PM
if you smell fuel, then check fuel pressure, look for leaks. Did you check the fuel pressure regulator? could have a torn diaphram sucking extra fuel into the intake. Are the plugs a normal tan color or black/wet looking?
Old Apr 14, 2020 | 05:49 PM
FromTheFar's Avatar
yes the plugs have this pitch black soot on them but it is dry not wet looking. And i will check the fuel regulator
bertusras
Jul 8, 2020 09:59 AM
italcarnut
Oct 12, 2015 12:26 AM
V_T5
Mar 22, 2015 05:51 PM
sstoynov
Oct 16, 2014 03:57 PM
SheenaMarie
May 26, 2011 04:14 AM
