1999 S70 running rough
My s70 has been running very rough. The car has absolutely no power. I can accelerate only in the higher rpms. At low rpms i am at a loss of power At constant throttle the car is very jumpy and idle is inconsistent/rough. When I first start the car it revs to about 3300rpm then slowly drops back down. I have cleaned my throttle body multiple times. It use to help for a little while, but now it is a very temporary fix. I am getting these codes p1053
p1108 p0442- I know this one is most likely my evap cannister j hose. I have ordered a replacement p1620 p1017 p1032 p1031 p1026 p1017 p1021 Any help would be appreciated. I understand that one of these codes is for my ECM and could be signaling other codes. Does it sound like the ECM is the issue, or should I look more into a new ETM? |
Man, that's like a Christmas tree. Oh, welcome to the forum.
I would reset the codes and see which comes back the soonest. Most likely the ETM is bad if it hasn't been changed within the past 24 months. |
If you have not done a tune up, I'd start there and work yourself down... But first clear your codes, then do it, and it wouldn't be a bad idea to check all vaccum lines.
*bump*
I have a similar issue going on with my 1999 V70. Intermittent rough idle/loss of power and the following codes:
p1021 p1026 p1031 p1620 was wondering if the original poster resolved the issue and what what the issue? |
My V70 drops idle to 500RPM when coming to a stop. Otherwise runs OK, good acceleration, solid RPMs on the highway.
