99 s70 no tail lamps, marker lamps or dashlights
I have a 1999 Volvo s70 that was working fine. I noticed the tail lamps, dash lamps, and marker lamps quit working. It blows fuse # 35 under the hood as soon as I turn the ignition to the run position. This is an accessory fuse but its keeping those lights from functioning. Has anyone ran into this, I have all the diagrams and they aren't very good. Apparently it runs thru several modules from fuse 35. And help would be appreciated.
Thanks Scott |
Well, one longshot way is you could follow the wiring path back from the fuse and disconnect items one at a time until you find the one that blows the fuse. Otherwise if you have a volt ohm meter, start checking at each connector to see if you can find a short to ground.
