'99 S70 - One Rear Wheel Doesn'the Spin Freely
So, I'm wondering if this can cause the car to pull to the right. The rear right wheel doesn't spin as freely as the rear left wheel. Would this cause it to pull to the right?
Also how would I go about fixing this? Could it be a sticking caliper? Cause the rotor on the wheel that is dragging has more wear than the other side. I recently had all brake pads and rotors replaced and the other side has little to no wear on the rotor visually. I want to fix this before I get new tires and potentially waste money because of uneven tire wear. |
1 Attachment(s)
Originally Posted by Ben_25
(Post 436038)
Originally Posted by Smith Volvo
(Post 436040)
either a sticking caliper or wheel bearing. Is there any discoloration on the brake disc? If so - its your caliper (see attached pdf) And yes - it can cause the car to pull to the right.
It's a solid mounted caliper with inner and outer pistons. One of the pistons may be frozen.
Also make sure the parking brake isn't the problem. The shoes can come apart or the cable could be sticking. Or it could be an adjustment issue.
Originally Posted by ES6T
(Post 436045)
Cheers! |
