ABS Pump Motor Assembly - How difficult?
2000 S70 non-turbo - Mechanic says ABS light code is a bad ABS Pump Motor Assembly. Replacement part is reasonable, but what is involved in replacing the beast. I cannot find any videos or instructions past replacing the module. There are obviously brake lines involved, but that should not slow me, a seasoned car guy, down too much. Thank you.
John, Cape Canaveral, FL |
John, it is pretty straightforward, remove the module, all electrical connections and brake lines. Replace the motor, re-assemble, and bleed the brake lines throughly. Check matthewsvolvosite.com and you might find a DIY there as well.
| All times are GMT -5. The time now is 09:18 AM. |
