Antenna/Mast Question
Old Feb 5, 2006 | 04:14 PM
postdoc99's Avatar
Default Antenna/Mast Question
My 98 T5 has no antenna mast (well, I found it broken under a spare tire). The antenna motor appears to be working fine, it turns on every time I turn on radio. Should I replace the entire antenna or can I replace the mast alone? I am asking this question because someone sells original masts on ebay. Thanks
Old Feb 5, 2006 | 04:28 PM
reg's Avatar
reg
Default RE: Antenna/Mast Question
It is a simple operation to replace the mast alone. Just feed the cable in and eureka...............you have a radio!
Reg
Old Feb 11, 2006 | 04:15 PM
You can replace the Mast only. BUT..... if the old one had the plastic break off inside the motor you will need to remove the motor and remove the old plastic peice.
Old Feb 15, 2006 | 08:42 PM
postdoc99's Avatar
Thank you folks - I bought a mast alone and it worked out just fine.
alecw81
Jan 7, 2009 05:22 PM
wellman
Sep 30, 2008 07:07 AM
PE**2
Mar 17, 2008 05:30 PM
Crispin
Oct 12, 2007 09:28 PM
fast850r
Jul 27, 2007 09:32 AM
