Axle nut issues
Buying your tools at harbor freight by chance? Got pictures of the busted tools?
Like rspi said, heat may help. How about a 1/2" CP pneumatic impact wrench?
This should do it..
Chicago Pneumatic - CP734H - 1/2
This should do it..
This should do it..
This should do it..
I don't think the air wrench will help. Already have one and I'm using a 4' cast iron pipe as an extension of the breaker bar. I'm not going to get more torque than that out of a 1/2" impact wrench. Yesterday, took it down to a mechanic to ask if he could use his 3/4" impact wrench to get it off. He says the 3/4" breaker bar with a good extension puts alot more torque on the nut than the impact wrench. He also said that volvo sometimes uses permanent locktite on those axle threads--probably to keep people from doing their own repairs. Said heating it up should do it, so I'm gonna give that a shot today. If I break another extension, then I'm gonna order a 3/4" drive 36mil impact socket to use with my 3/4 breaker bar.
...either that or maybe I'll try cutting the nut off with a grinder.
I ordered a 3/4" drive 36mm impact socket from napa, so I'll try heating it again and using the 3/4 breaker without an adapter when it comes in tomorrow.
Any other suggestions?
