b5234t engine
just wondering , is there any differnt between the b5234t3 b5234t5 and t6 engines, couz, i blew my b5234t3, just wondering if i can put a 850 t5 engine in my s70 t5, or. there any problem with it?
RE: b5234t engine
all i know is that i have(bout 95 percent sure on this) the b5234t3, which is the low pressure turbo. im guessin the b5234t5 would have the more powerful t5 in it, and i didnt know the s70s came with a t6. thatd be a nice project tho
RE: b5234t engine
the B5234 is 2.3L. extensions: the T3 is fwd/automatic, T4 is awd/manual, T6 is awd/automatic. any will work. also, i dont see any reason you couldn't put an 850 turbo block/head in your car as long as its a '98. you can only use the block if you have a '99-00. the '99+ heads have coil packs no distributor.
