A/C drain
Old Apr 8, 2008 | 01:13 PM
nomadly's Avatar
Default A/C drain
i have what ithink is a blocked condensate drain (sounds like a half gallon of milk sloshing behind the dash).also, when i make lefthand turns now the blower wheel whines and slows until i come out of my turn. oddly, i had a blocked drain tube on a rear a/c on a suburban once and it was simply that the rubber tube had closed up at the end. Where does the drain hose from the evaporator terminate and can i get to it if i raise the car to get under it? thx,
Old Apr 8, 2008 | 06:13 PM
Default RE: A/C drain
You really can't get to it from under the dash.
Best way is to remove the lower dash on one side. Then pull the carpet back then remove the black cover and you will see the drain hose where it goes to the floor.
Old Apr 9, 2008 | 07:31 AM
nomadly's Avatar
thanks. where does the hose terminate under the car? i'd prefer to start there before i give an afternoon to dismantling half the dash.
Old Apr 9, 2008 | 05:37 PM
You really can't get to it.
It exits under the car like just infront of the shifter. There is a heat sheild under the car hiding it.
It will take you about 10 to 15 minutes to get to it from inside.
jbarnes
Jun 12, 2013 11:46 AM
Chris Campbell
Apr 2, 2005 11:18 PM
roughyear
Feb 10, 2005 10:02 AM
x1sjwebster
Feb 9, 2005 02:17 PM
PHLI72
Dec 14, 2004 10:04 AM
