Check Engine Light P0172 bank 1 system too rich?
Anyone have any answers
Please leave details about your car when you post. That code is usually linked to a loose vacuum line. Often my vacuum line that connects to my PCV has come loose.
same problem
I have a 98 s70 and i have that code pop up from time to time. i have replaced both o2 censers. It all started after i replaced my cat it was plugged up. and i have had to replace the flex pipe.
Same for me
Please let me know where to locate the PVC Hose. This is happeng at 840 RPM Here's the stats: This is my first post so if this is too much info, just let me know: Replaced both 02 sensors last year and MAF 3 years ago-
Freeze Frame Information: 1. DTC for which Freeze Frame was Stored - P0172. 2. Fuel System 1 Status - Closed Loop - Fault With At Least One Oxygen Sensor. 3. Fuel System 2 Status - Not Supported. 4. Calculated LOAD Value - 2.75 %. 5. Engine Coolant Temp - 210.20 °F. 6. Short Term Fuel Trim - Bank 1 - 6.25 %. 7. Long Term Fuel Trim - Bank 1 - -5.47 %. 8. Engine RPM - 840.00 Rpm. 9. Vehicle Speed Sensor - 0.00 Mph. |
Model year and mileage could be useful to guess what is going on.
BTW, I am no mechanic nor car expert. I am just a new Volvo owner who is struggling to keep my car on the road. What I notice unusual from my experience is that your LTFT is negative while you get rich condition code. If it was from vacuum leak, I would expect a lot higher LTFT, as ECU would trying to compensate un-metered air. So, what I would rather guess is something like this https://volvoforums.com/forum/showth...ighlight=p0172 Well, I have to admit that this still does not make clear sense because your problem is under idling not under boosting. In addition, if I have to use silicone sealer, I would use sensor-safe one. |
Appreciate the feedback, mine is a base model, by accident I found a hose from the intake manifold that goes to the evap valve that was original and virtually fell apart while checking it. Replaced and so far no code :-)
