-   Volvo S70 (https://volvoforums.com/forum/volvo-s70-33/)
-   -   Code 1308 (https://volvoforums.com/forum/volvo-s70-33/code-1308-a-54737/)
chachouu Jun 9, 2011 05:20 PM
Code 1308
I REPLACED what I thought was a faulty accelerator SENSOR.
I used a cheap Scanner to erase the code,it says erased but as soon as I start the car the CEL came back on.
Do I need to use a better Scanner that have option to reset or is it another problem.
Carrots Jun 9, 2011 07:12 PM
Any OBD-II reader that can read the codes should be able to erase them. The code you posted is for "accelerometer signal too high." That one often indicates a wiring fault rather than a sensor fault. It can also indicate a problem with several other sensors that share a power connection inside the ECM. PM me your email- I'll send you something that should be of great help in diagnosing this.
chachouu Jun 9, 2011 07:59 PM
PM sent.
But I only stated that,because I see some scanners have options to Reset and not jut erased.
