Cylinder layout?
New member here...have CEL reading Cylinder 1 MISFIRE...assume it's the coil...this is the only vehicle of ours I have no diagrams for...it's a '99 S70 T5...facing the car with the hood open, from left to right (my left), which cylinder is #1, which is #2, etc???
Thanks for any advice I might receive... I'll check back later...will troubleshoot code by swapping ignition coil with one in another cylinder to verify correct Trouble Code... PS-have 142k+ miles... |
Welcome to VF. Here is what you are looking for.
http://www.fixya.com/uploads/Images/D92ECE6.gif Also for it not being the coil, it could very well be it. Your car uses a coil pack for each cylinder so I would check it while you are in there. |
