Dashboard switch wiring
Old May 2, 2009 | 04:07 PM
yoyoman's Avatar
Default Dashboard switch wiring
I had my dashboard replaced, and the mechanic didn't notice that the replacement dash switches were not the same as the original car. So, I am missing the info switch and the front fog light switch. What does replacing these entail? Did the wiring harness be/w the years and makes vary?
I have a 1998 S70 T5, but I don't know what the donor dash was from. I am assuming he just used the wires and switches that were on the dashboard I got from a wrecking yard.
Old May 2, 2009 | 04:48 PM
The wiring should be the same and the switches should also be color coded to the back of the switch.
Old May 2, 2009 | 08:03 PM
yoyoman's Avatar
If it's color coded, is the reinstallation as easy as taking it out of the old one and just popping it into place on the new, into the exact same slot?
Old May 2, 2009 | 09:13 PM
Yes it should be that easy. Remove the flat plate where the switch should be and the harness should be right there.
Old May 2, 2009 | 10:06 PM
That is exactly how it is in our S70. But... hopefully nothing was done to your trip computer. If he did something to swap out a part in that, you may have to get the trip computer re-programed. Expensive!!!
Old May 2, 2009 | 10:35 PM
yoyoman's Avatar
The trip computer and other info items are niceties, and so I can live without them if they came at some extra price.
Well, I'm not going to worry about that yet. I am hoping for the best!
Old May 7, 2009 | 12:45 AM
yoyoman's Avatar
yay, my info switch has been reinstalled and works. Unfortunately, the fog lights aren't coming on. I thought they used to work ...
I guess I'll take out the bulb and check the filament. Aside from that, what else can I check? The green led light above the switch comes on, so I know that the switch is working. I noticed on ebay there are fog light relays. Is there a relay for both sides or just one?
Old May 7, 2009 | 04:17 AM
Should be 1 relay for the fog lights.
Old May 8, 2009 | 09:34 PM
Check for power at the foglight with a test light.
sdl92
Jun 22, 2013 07:19 PM
Echoe
Aug 26, 2009 12:08 PM
Echoe
Engine & Internal
Aug 20, 2009 12:07 AM
jhcblack1
Aug 31, 2008 07:58 AM
maron96
Apr 28, 2006 12:13 AM
