Door will not open...
The rear passenger door on our S70 will not open. Anyone have a tip for me? My daughter said that she hit the unlock button and someone pulled the handle and it jammed.
Any solution to this problem? I'm having the same problem. Also, today my passenger door can't open from the inside. Can't even move the handle. It can unlock, lock, and open from the outside. Just can't from inside.
A code in the DLM will keep the door latch/lock module from working. Or the door lock/latch module is bad and only way to fix is replace, happens all the time.
Originally Posted by Lifesgoodhere
(Post 343224)
A code in the DLM
will keep the door latch/lock module from working. Or the door lock/latch module is bad and only way to fix is replace, happens all the time. |
Anyway you can point me to the correct part I need? Noobie here.
How much would this cost to fix too?
(Post 343224)
My door had a stuck latch. It was in the back so I pulled the back lower seat cushion, then pulled the door panel, then took a screw driver and started poking at the door latch. I hit a part of the latch mechanism that popped the latch and caused the door to open.
| All times are GMT -5. The time now is 07:30 AM. |
