Drive shaft replacement
S70 1999AWD Turbo
I need a drive shaft and detailed Instruction on how to remove and replace. Is this a job I can do in my garage with jack stands or is this a heavier job that needs lifts. what else has to be removed to get the shaft out. The shaft was inspected by a Volvo dealer. I was told the bearing was going and it posed a danger to let my son continue to drive the car. They want 1300.00 for the shaft (new). Is there a rebuilt source in Illinois. |
RE: Drive shaft replacement
I assume they are saying the R/F one?
Yes rear to front, Center bearing was shot
any ideas on a used or rebuilt shaft
Rebuilt ones are usually junk.
New ones usually don't last all that long either. It is a pretty poor design. There is allen head screws holding the front and rear of the driveshaft to the transfer case and rear end. There is also a couple of 12 MM(Well maybe 4 of them) screws holding the center bearing up to the body. |
