Driver Window Knocks
The driver window when just coming up from the open position gives me a knock, does not hinder the upward flow of the power window though, the glass is tight in the door not loose, any suggestions.
Thanks JC |
RE: Driver Window Knocks
Remove the door panel and check the rear window guide.There is a screw or a rivet that goes from the back of the door to inside.The guide breaks at the bracket for the screw.
Is there a link on how to remove the front driver door panel TECH. Thanks Jim.
No I don't have a link but I will tell you how to do it.
First remove the trim ring around the inner door handle.Careful the plastic is sharp.Grab the trim ring on the outside on the top and pull down and out it should come loose.Then remove all the way.Next pop the cover off in the grab handle to close the door.There is a t-25 screw there remove it. Then start at the bottom of the door panel and pull out on it.The rest is held to the door with clips. FYI: Some peices of the door panel might need to be glued back in.The glue from the factory was poor. |
| All times are GMT -5. The time now is 04:13 AM. |
