RE: engine check p1307
I replaced the A/C high pressure switch.
I also beleive the fuel tank pressure sensor is on the same circuit as well.
Hi there.
You where right the first time. The A/C pressure sensor was bad. I checked for the bad code, and then I replaced the sensor, and checked again, in a short period of time (10 minutes). And it is wrong. The bad A/C sensor caused the ECM (computer) to get hot, and I needed to let it cool down of for an hour before checking it again. The resistance between terminal #1 and 3# on the bad sensor was 8 ohms, and on the good sensor the resistant is very high. Thank you for your help. You are a real Pro. Simon |
No problem anytime.
Im glad I could help. |
