Engine Code POO14?
We recently replaced the intake and exhaust valves in our 1999 Volvo S70 and now it is running rough and showing an engine code of POO14 What is causing this and how do we fix it?
P0014 ECM-641A Camshaft control, exhaust Faulty signal
Seems,from a quick search, that there must be something with the timing, this code appears after a timing belt change quite often, if the cam moved out of timing marks
