| LinkFL |
Jun 24, 2018 02:34 PM |
Do you have any information about the different RNC T5 (B5254T3, B5254T4, B52_4T_, - B5254T14) engine specs? I am mostly interested in the differences in the cylinder head interchange info, camshaft specs, manifolds, turbos, and flow information. Also, any differences in the bottom end that could be worth mentioning. I currently have a B5254T3 that needs a head gasket, at the very least, and since I am removing the head I will also be replacing everything I can while I have it apart. I will be using a timing belt and water pump kit from an R series to get better coolant flow and I would like to know about other parts that could be swapped to improve the performance, especially if I end up needing a head. I have tried to start a thread showing the differences but it is a slow moving thread. I think this info could be very useful to many other Volvo owners who want improvements when doing repairs. I did try starting a thread on this topic but not much information has been added yet.
