Originally Posted by elcs70
(Post 250635)
i just replaced my PCV system 1.5 years ago. how should i go about maintaining its cleanliness?
Originally Posted by Bobec
(Post 250637)
Here is the one I disassembled
https://volvoforums.com/forum/members/bobec-25604-albums-v70-etm-632/ it is from our 01V70. You can come by my place any time and I'll show you how the board is encapsulated in silicone conformal (do you know what conformal is?) and all the potting and the o-rings. The magnetti marrelli ETM was an engineering masterpiece for its time. It was before hall effect technology was mature and even Bosch took a chance using hall effect in 03. Yes the ETM in 03 was a Bosch not a magnetti marrelli check VIDA. |
so, i am not currently having any issues with mine, but if i were to replace mine in the future, the best option seems to be a Magnetti Marelli ETM with a ?xeMODex? something or the other? (best option besides a junkyared pulled ETM) anyway, how do i come into possession of a Magnetti Marelli ETM? a quick google search did not bring me to any websites to do this.
Question for you guys
I have an opportunity to purchase a 2000 S70 with 190k on it, but the ETS light is on. In your guys opinion should that prevent me from buying the car? Otherwise everything else is fine and the car seems to idle fine?
Worst case scenario, you need to spend at least $600 to replace the ETM. That's in addition to some, or all, of the following standard post-purchase items:
Timing belt/waterpump: $250 DIY, $800 Shop Shocks/Struts/Mounts/Isolators: $400 DIY, $750 Shop Pads/Rotors: $300 DIY, $500 Shop Transmission Flush: $129 Shop Other Typicals (oil & filter, tires(?), air filter, cabin filter, coolant flush): $200 -$500 DIY---> $1,000 - $1,700 Shop I also bought my S70 for $2,000. I then promptly spent an additional $2,500, combining my own mechanical skills and labor with those of a trusted independent European auto specialist. I could have easily spent around $4,000 for everything to be put as straight and tight as it is on this vehicle. I love my GLT like I love my favorite old leather motorcycle jacket. It looks great. It feels great. And I feel cool when I'm in it (regardless of my wife's opinion). But that's because I don't have to dip that deeply into my already strained retirement fund because I keep it tuned perfectly, mostly by myself. You need to understand that the S70 is a time-tested (don't forget, it lived many of its years as the 850) nearly perfected piece of machinery. But it has 2 distinct weaknesses: 1) If you don't address tiny, annoying issues that could be considered endearing quirks in other vehicles, they will rapidly grow into serious and expensive problems; and 2) The ETS system will inevitably fail, unless you are well-versed in the specific means you must employ in order to prevent that failure from happening. If this isn't the first car you've worked on yourself in order to keep it "tip-top," you're in for a treat. It's like a set of LEGO's for grown-ups. If you've never replaced your own brake pads on a car, you need to steer clear of this vehicle. Because she'll either bleed you slow and steady with the small stuff, or she'll do something REALLY cool like suffer a catastrophic system failure (like an ETS) 3 days after you pay for a new roof on your house... |
Thanks
Hey loudgoldwing thanks for all the info. I have a 2001 V70 and am considering this for my Daughter who is a new driver. I'm thinking it will be a great first car. Thanks again.
