S70 Water in spare tire well.
Old 11-11-2018, 01:16 PM
Ricco4083's Avatar
Default S70 Water in spare tire well.
Have read other enteries about problem. I had at least 1 gallon in mine. No drain of any sort that I can see. Any one ever make a.drain ?
Old 11-11-2018, 02:40 PM
I'd use a shop vac to pull the water out, then look around for how the water is getting in - ie around the trunk seal, tail light seals etc and fix that with some RTV or similar to get the seals to keep the water out. There's no drain since the water isn't supposed to be in there...
Old 11-11-2018, 02:49 PM
Ricco4083's Avatar
Default Water
Thank you. I will probably add a drain. Will re check all seals, etc.
ashgardner
03-23-2024 04:58 PM
jdbs3
11-28-2017 05:05 PM
strelnik
02-06-2016 07:14 PM
jimbo48
03-07-2013 05:43 PM
Volvoom
12-13-2008 03:44 PM
Quick Reply: S70 Water in spare tire well.
