Evaperator replacement instructions
#21
#27
Ac conditioning
Hi guys,
My AC wasn't working and since everybody was telling me that the evaporator would be the problem, I decided to change it. After long hours of work, and with the help of Tech(thank you) I did get to the evaporator. I was surprised that I neither the pipes had no sign of freon nor the evaporator. I am confused now. Before changing the evaporator i checked and recharged the system(i believe I did so) since the gauge was showing 40 psi which was on the border with alert area. The ac compressor clutch was engaging but no cold air. Would it be possible that the evaporator isn;t leaking but still not working. Btw Tech u wrote in your post that u replaced the evaporator but that wasn't the problem. Did u find out what it was?
Help. I don't know what to do.
#29
#31
For the last couple of years, the check engine light comes on every month or so in my 98 S70. When I check using my ODB tool, it always reports a "small evap leak". I was told by my mechanic (who wasn't able to resolve the issue) not to worry about it. So I just reset the trouble code and it's good for another month or so. Is this referring to the AC evaporator?
#35
ac, c70, core, dash, evaperator, evaporator, heater, installing, instructions, replace, replacement, s40, squeak, step, volvo
