Faulty sensor?
After my car warms up, the red radiator light illuminates on my dash, the only other time I have seen this light was seconds before my heater core blew. But I just started driving this car again after a ton of work on the car, and my temp gauge stays right at the 3oclock position and the coolant levels are fine. Would this be from a faulty thermostat?
weak. the car seems to run fine, i recently had the water pump and timing belt replaced, but this just started happening after i had the timing adjusted. What does that light refer to? besides a hot radiator? cause it will come on when the car is cold...Thanks rspi
I seem to be having a similar problem, although mine just started a few days after having a heater core hose leak replaced. I had the hose replaced, then a few days (and nearly 1000 miles later) the light comes on. I thought maybe they had missed another leak in the coolant system, but when I check the coolant level on the expansion tank it appears to be right where it should be. Is this another case of some wiring issues? Any help would be appreciated on how to do a little fiddling with it myself.
analogies
Mar 4, 2013 12:11 PM
PHIL_V70_GLT
Feb 22, 2009 09:49 PM
99, cold, expansion, faulty, gauge, light, red, s70, sensor, tank, temperature, thermostat, volvo, volvo740gle
