fog lights
I recently bought fog lights for my 1999 s70. The wiring and switch is all there, so i figured easy enough, just plug it in and go. When i went to plug the fog lights into the factory connector i realized the pins on the fog light socket are way too big to fit the factory connector. Anyone have any idea of what kind of connector i need? and or where to find one. I cant seem to find a picture of the connector from the front so i do not know which ones to buy. theres a part number-DEPO 373-2007R. Any help would be greatly appreciated
Where did you get the fogs? Most people get them from the junk yard or from a Volvo supplier.
Also, if you want the "pre-wired" Volvo system and switch to work you will also need:
- Head light relay with FOG option
- J Relays for under the dash.
- Jumper for relay panel under the dash.
HelgaTheS80
Mar 9, 2007 03:20 AM
