Heated Seat Switches
Hey Everyone, I'm new to the forum so first let me say that I drive a 1998 Volvo S70 Turbo with 150K and dont plan on getting rid of it anytime soon. Now for the reason I am posting --both my heated seats switches have stopped working and I would like to get new ones but I am having trouble finding them online...does anyone know of a good website I must be missing? Thanks! |
RE: Heated Seat Switches
Check the fuse first, it's unlikely both switches would go.
If it is not the fuses, try going to EBAY and searching "98 Volvo S70" or "Volvo S70 Switches". I have purchased several replacements on there.
Before you buy switches, have the continuity tested on each seat to see if your heating pads have burned out. Not likely that both would go at the same time, but there's no point in buying switches if the pads need to be replaced. If you have a little multimeter (usually you can buy a cheap one for $20), set it to test for continuity, then unplug the heater pad for each seat and test it. If current can't transmit all the way thru, then you know it's gonna bea pad to replace.
