Help: Found water on my floor.
Hello
The car has been sitting on my driveway for a few days not. It has snow all over it. This afternoon when I opened the driver side door the floor carpet was soaked with water. Same with the left passenger side. But the left front and rear passenger side carpet dry. I know the windows where completely closed and the car does not have a sunroof so that cant be the problem. Has this ever happened to anyone here. |
Are you sure its water? Antifreeze leaking from the heater core can do that. If its water, the leakage could be coming from a host of things. Was the windshield replaced? Could the A/C drain be plugged. The floam around the doors could be leaking.
I touched the water and smelled it and does not smell like coolant so I would rule the heater core out. Also if the heater core was leaking the water color on the color would be blue or green right.
And I don't know if the winshield was ever replaced or not. I bought the car back in October so I only had it since 5 months. Does not say on the carfax report that the windshield was replaced.
Carfax only contains what is repoorted. Look around at the door seals. My son has a drip that drops on him during rain. There is a small tear in the rubber. I've never replaced a seal but I know its a job.
Also, is the cowl at the base of the windshield blocked up with tree junk? Was the snow blocked up on those vents?
