Help ID this line ... P0172 related?
CEL came on this afternoon, and it's a P0172. I guess I was glad to see it since I have been noticing some hesitation at around 1500 rpm, occasional stuttering at idle, and rough starts the last two morning. So, after scanning some posts, I went looking for broken vacuum elbows and hoses. Nothing stood out as immediately obvious, but I did come across this deteriorating line.
Can someone ID this line so that I can replace it? This is on the passenger side near the firewall. Will hot water and dish soap be enough to clean the metal line? I should probably clean it to help watch for future crud.
Here is the line:
Turbo Coolant Return Hose
It is linned so I wouldn't use anything light weight for longer than a few days.
OK_v70_5spd
04-08-2008 11:12 AM
