Help volvo 70
Guys, How do I remove the plastic tab on dashboard s70.
Cheers https://cimg4.ibsrv.net/gimg/volvofo...d7fd41b73d.jpg |
Remove the plastic tab? Those are what holds the dash board in - you get to the bolts that screw into them under the plastic cowl.
Originally Posted by hoonk
(Post 497601)
Can you return the dash you ordered, explaining the problem? Otherwise I don't really know a simple solution except what you proposed....redrilling.
Originally Posted by Psaboic
(Post 497842)
It's a bit too late to return the dashboard. I can't figure out how to remove the plastic tab holder. I found two screws on either side holding the sides down. Is the rest of it glued down. Could you please send some pictures as to where these screws are. Cheers |
Sorry, I have no pictures but I would asume that if there are no screws holding it down, then it has got to be two pieces glued together, or one whole molded piece. You could always try carefully cutting it apart with a small cutting tool, then screw or glue it back in place when you are finished
