How to remove battery from S70
I know it sounds silly, but I'm stuck, unable to take out the battery. My S70 has not been used for over a month and now it can't be started. I'm going to take the battery to AutoZone for a free recharge. But oddly, there are not any of the usual bracket, rod, or screws securing the battery, none of these usual holding-down mechanism is visible. Yet after removing the terminals, the battery remained firmly in place and wouldn't even wiggle a bit. It's as if the battery is welded/glued at the bottom.
Anyone have experience and know how the S70 battery can be removed? |
RE: How to remove battery from S70
you need to pull the clips off at the base and push to the left i beilive. Then it should just pop right out.
It worked exactly as you described. Thanks for the quick help!
Mine doesn't have any clips and probably slides around, where can I get some @ a reasonable price or just use zip ties?
