Immobilizer Broken
well my car wont start because the immobilizer got broken off when someone tried to steal it...can onyone tell me how can i wire my 98 S70 to work from a switch because i also think that my ignition switch is broken because it looks like they tried to shove something in there...or if someone knows a trick to get around the immobilizer then let me know plz...anything that anyone can do to help me out...thanx in advance guys...
RE: Immobilizer Broken
Is just the switch messed up so that you can't turn the key?
the key turns all the way to the 3rd position but nothing happens...the interior lights work the keyless entry works, in my opinion everything in the car that is supposed to work when the car is off is workin even when i put the key in and turn...the engine is fine but for some reason the car is not getting no electrical power...any help would be appreciated
Do you have power at the little starter wire when the key is in the 3rd position?
| All times are GMT -5. The time now is 10:11 AM. |
