-   Volvo S70 (https://volvoforums.com/forum/volvo-s70-33/)
-   -   instrument cluster dead Plus ETM trouble (https://volvoforums.com/forum/volvo-s70-33/instrument-cluster-dead-plus-etm-trouble-50763/)
mark_disfree Feb 25, 2011 10:12 AM
Hey All,
I have a 99 S70 T5 showing all the classic signs of a bad ETM module, (ETS and “check engine light” are on, rough idle, turbo is no longer working) but additionally my dash gauges are dead.
From everything I have read this seems like the recalled ETM issue, except when I called Xemoddex they said the dead gauges were not the ETM and something additional must be wrong.
They suggested a bad relay under the dash could be the culprit and that I could test it by swapping it with an identical relay that controls the radio & climate control ( also found under the dash). I tried this but saw no change.
So what I am asking is for ANY possible causes for a dead dash.
Thanks a bunch.
Carrots Feb 25, 2011 01:29 PM
Check all the fuses. Use a "fuse tester" or a multimeter on the continuity setting to avoid pulling and looking at all of them.
mark_disfree Feb 25, 2011 02:25 PM
Good call on checking the fuses. I looked before but after pulling a bunch I kinda just glanced at the rest. I will use my multimeter and look again. Anyone have a clue which fuses might relate to the dash?
