no air is blowing into the cabin
how do i get to the fan that blows air into the cabin because im sure that my ac and evrything works except that
just bought a 98 s70 and dont know much about it need help now ! |
Do any of the vents work?
0 means off. Can you hear the fan blowing? If a resistor in the control goes out, you can often run it on 5 (more max) and that is like an override.
all my vents are clear and i cant hear the fan i can hear the ac turn on and i need to know how to get to that fan
It is possible that your fan motor is blown. They best thing to do is switch the flan slider all the way right, to the fastest setting. If it doesn't come on then, I would assume it has blown. What you can do is access the fan and give it a spin (turn) to see if it catches and starts to work. They usually slow down before they stop but that is not a guarentee.
ok well how do i get to the fan
i dont know were that fan is thats the problem
Behind the glove box: https://volvoforums.com/forum/showth...ht=replacement
hey hanks everyone for their help
