speedometer not working
Old 09-10-2012, 01:19 PM
dseam's Avatar
Default speedometer not working
I*ave. 98 s70. Speedometer works when it wants to no lights on dash come on & the car runs runs fine could it still be the abs module?
Old 09-10-2012, 09:01 PM
Did you scan for codes?
Old 09-11-2012, 01:22 AM
matty moo's Avatar
Does the ABS light come on at startup, then go away? If not, that bulb is gone.
usually on a 98 with a speedo issue that isn't ABS related, the service light will blink. Not the CEL, but the actual service light.
Old 09-11-2012, 07:41 AM
dseam's Avatar
Good morning. Their are no codes & when i turn on ignition all lights including abs light come on then go out service light was staying on awhile longer but then goes out when speedo dont work neither does cruise control i can pull over turn car off & resrart & it might start working again but never throw a code
Old 09-23-2012, 10:01 PM
Pej's Avatar
Pej
Pej is offline
Default abs module
I am 99% certain it's your ABS module.
those are the symptoms.
Old 11-30-2017, 09:07 PM
spiritfree's Avatar
Just fitted new turbo to my 2000 volvo C70 & on restarting speed /abs & engine warning lights stay up - WHY??? There were no problems of any sort before turbo work - I think its a electrical connection possibly not reconnected by mechanic - help !!!!!!!
janeofdrama
05-24-2010 08:02 PM
marcello1965
01-24-2010 04:25 PM
avinash
01-18-2010 06:24 PM
jtvrba
12-13-2006 08:36 PM
lisrobbe
02-27-2006 09:50 PM
Quick Reply: speedometer not working
