No signal ligts on driver side
Old 04-16-2019, 08:16 PM
Jwalker47's Avatar
Default No signal ligts on driver side
I have a 2001 volvo v7o 2.4T. I have replaced all bulbs and switch but still have no signal light on driver side. Please help
Old 04-17-2019, 07:48 AM
did you check fuses? which light is not working - ie marker light or the directional?
Old 04-17-2019, 07:56 AM
Jwalker47's Avatar
Default Fuses
Yes all fuses are good. All lights work except turn signals on driver side
Old 04-17-2019, 07:57 AM
Jwalker47's Avatar
Default Fuses
Even with flashers on rhat side doesnt work
Old 04-17-2019, 09:01 AM
Psaboic's Avatar
Well, if all the bulbs, fuses, and switch check good, it is down to either the flasher unit, bad ground, or wiring. I would suggest finding a wiring diagram for your specific year online and start from there.
Old 04-17-2019, 10:45 AM
sounds like the turn signal flasher relay. You can google for vids to see where it is or reference the owners manual. Check out IPD, FCP Euro, eeuroparts etc for the part number and cost. Should be in the $10 range.
cdubb
08-08-2020 04:48 PM
aser9000
08-02-2019 11:58 AM
ShaunWaves
03-12-2016 08:42 PM
dcjcdc
04-10-2010 02:02 PM
castiron
09-30-2005 09:03 PM
Quick Reply: No signal ligts on driver side
