No signal ligts on driver side
I have a 2001 volvo v7o 2.4T. I have replaced all bulbs and switch but still have no signal light on driver side. Please help
did you check fuses? which light is not working - ie marker light or the directional?
Fuses
Yes all fuses are good. All lights work except turn signals on driver side
Fuses
Even with flashers on rhat side doesnt work
Well, if all the bulbs, fuses, and switch check good, it is down to either the flasher unit, bad ground, or wiring. I would suggest finding a wiring diagram for your specific year online and start from there.
sounds like the turn signal flasher relay. You can google for vids to see where it is or reference the owners manual. Check out IPD, FCP Euro, eeuroparts etc for the part number and cost. Should be in the $10 range.
