O2 sensors
Volvo s70 non turbo.
I wanted to know if the rear sensor is the same as the front. I have my Catalytic converter removed,so i wanted to use the rear sensor up front, it is newer,I,ll just plug the front one in the rear and won,t power it. |
I think the only difference is the legnth of the wires.
Thanks RSPI.
Should i cut the wire shorter or it doesn,t make any difference |
Should not make a difference. Just strap it up so it doesn't drag the ground.
Much aprreciated
