Performance and tuning
So i built an na motor top to bottom now its studded with a 22t turbo and its really lean 17lbs of boost. what size injectors should i go with i was looking at some 1000cc 95lb this is going to be a track car that i plan to drive alot mileage isent a big deal and i run premium with 105 additive so i was thinking atleast 800cc, any ideas?
Do you have a target HP number in mind? Is your ECU tune / wastegate set up for 17lbs steady state or peaks at specific RPMs?
Here's a link to a handy calculator: https://fuelinjectorclinic.com/flow-calculator Assuming your target is 400 HP, your fuel pressure is 45 PSI and you choose a racing duty cycle of 85%, this site is suggesting a 600cc injector is the one (note that's about 80% larger than stock which I think is 325ccs or so). |
I lied its a stock turbo, guy i got it from said it was a 22t, and the plate is gone, but the more digging i do i think its stock
