Power steering noises
i just replaced the power steering pump on my 1999 s-70 an now the wheel turns itself left an right while makeing all kinds of crunching sounds like the whole front end is coming apart etc
http://www.troublefreepool.com/images/smilies/wave.gif Welcome to Volvo Forums rrrrr6
Please ask your questions in the section of the forum for your model. I moved this to the S70 section plus you tacked it onto a very old thread. What was the reason for replacing the pump to begin with ?? |
power steering s70
no power steering bad pump
If your fluid full? Do you notice any leaks along lines or at the cap, and are the hoses all tight?
Also, what kind of fluid are you using? The S70 is supposed to use Dexron ATF. |
