-   Volvo S70 (https://volvoforums.com/forum/volvo-s70-33/)
-   -   power steering pump (https://volvoforums.com/forum/volvo-s70-33/power-steering-pump-963/)
sod Feb 10, 2005 11:04 PM
power steering pump
My daughter just called from college. Her 1999 S70 with 73,000 miles is making a front end noise so she took to a mechanic. They told her it the power steering pump going bad and needs replacing. Qouted her $1000 to $1200 for the job. Wow, does this sound right? Her school is 600 miles away, so my having a chance to help her out is out of the question. Be advise on wehter the pump is a common problem and part availability on the aftermarket. Thanks
tech Feb 11, 2005 12:20 AM
RE: power steering pump
They go bad sometimes.Not all that often.Did she say what kind of noise it is making and when it is making it?If it is kinda like a squeeking/grinding noise at full turns then the steering stops need to be lubbed.If it is a whining noise it is possible the pump is bad.Have her make sure the fluid isn't low it is easy to check the cap has a dipstick in it.It is kind of a pain to replace the pump the new one has no pulley.The pulley on the old one is plastic and sometimes breaks when trying to remove.
http://www.partsamerica.com/PartDeta...tDetails%2Easp
The link is for discount auto parts and there is a price there.
sod Feb 11, 2005 09:07 PM
Thanks Tech,
I will call her tonight to get more info. I feel better after seeing the aftermarket price. i think I'll let her boyfriend check the the fluid. It seems that no matter how many times I go over the need to check the car fluids, the daughter gives me the ya, but I not really listening. Kids, don't you love em.
tech Feb 11, 2005 10:05 PM
Ok let me know what she says.And I know the feeling you can tell the kids till you are blue in the face and goes out the other ear.:D
alecw81 Feb 24, 2005 04:49 PM
Thats funny... I'm always reminding my parents to check their fluids ;-)
On the subject of power steering issues, I'm getting a grinding/rubbing noise when the wheel is locked all the way in one direction... low fluid or steering stops need to be lubed? I just bought my 98 S70 two days ago.
tech Feb 24, 2005 06:52 PM
Steering stops need to be lubbed.
alecw81 Feb 24, 2005 10:56 PM
Haven't been able to snatch up a Chiltons or Haynes yet... link to instructions/Diagram?
tech Feb 24, 2005 11:53 PM
Climb under the front of the car and look for white plastic peices on the front of the lower control arm.Lube that with grease.Then you will be fine.
