power windows
I have a 1999 s70. The power windows and sun roof are not working. It is not a fuse problem and there is nothing blocking the windows either. The back windows are down and won't go up and the front windows are up and won't go down. I would appreciate all the help I can get!
It may be the master switch, I know in the wiring diagrams it and th sunroof are two seperate circuits but replacing the master switch can fix this issue, I don't know why. Also I do believe the same relay powers both circuits.
I agree with volvo cars on this one. I dont know much about these cars yet, but I am currently having the same problem. I was told the same thing, but I didnt want to buy a master switch unless I knew that was the problem. I took it to a mechanic and it was my problem. Also they are both run off the same fuse/circuit breaker (#37 I think. Check the owners manual under fuses.) To get to it you need to take the cover off your fuse box (just 4 torx screws) Check that to make sure there is nothing obviously wrong. I wish I could be more help, but I wanted to inform you about my experience.
All the controls do not work. I was planning on taking the door panel off but only as a last resort. The manual says "there may be something blocking the window" but nothing is visible so i guess i should take it somewhere.
mrbaja
Dec 17, 2005 03:41 AM
