Replacing window track
This is my first post, so I'm sorry if I'm missing any details that i should have in here. Anyways, i have a 2000 S70, and the motor that rolls the window up and down broke off, in order to fix this i have to take off the whole window slide and swap the part out. I have all of the bolts out, but it still seems to be stuck. I'm working on it right now, and trying to see what the problem is, but i can't get behind it. If anyone has any links to forums such as this, or knows how it would be appreciated.
Thanks, Clint. |
RE: Replacing window track
Usually you need to move the window/regulator up and down some to work it out. The geared section is bigger than the hole it comes out of. So it like needs to go all the way one way the pull the top half off the move it the other way to get it the rest of the way out.
