rough idle, not MAF sensor. 1999 S70 GLT
Hi all,
I've researched this issue and found out it could be a dirty MAF sensor, so I disconnected the MAF sensor and started the car but the idle remained rough. I've read that cleaning the throttle body helps so I got CRC throttle body and air intake cleaner but on the bottle it says not to use on turbocharged engines? And I have no idea where the throttle body on the S70 GLT is anyway... What else could it be? |
Do you have a CEL?
Originally Posted by rspi
(Post 297546)
Do you have a CEL?
That means you have a brake light bulb out.
You have a '99 so you may have a bad throttle control. They go out a lot in those cars. If you do not have a cel, you are likely not missing. |
(Post 297562)
You have a '99 so you may have a bad throttle control. They go out a lot in those cars. If you do not have a cel, you are likely not missing. And thank you for the brake light answer, very helpful :o |
Missing means that one of the cylinders in your motor is not firing. That is the most common cause of rough idling. You have 5 cylinders and if 1 of them is not firing, it will cause a rough idle. How many miles does the car have on it?
(Post 297587)
I might also add that the car dies every now and then while driving, usually during stops. |
https://volvoforums.com/forum/volvo-...-stalls-55928/
In that case, try this first. Fuel pump relay. |
