rubber door seal
rubber door seal
My rear door seal things seem to droop down constantly. Does anyone have any recomendations on how to fix the problem without becoming permanent? I am starting to think rubber cement would probably be OK. Thanks.
http://img364.imageshack.us/img364/3458/dscf0128vp3.png
http://img364.imageshack.us/img364/7359/dscf0129be8.png
RE: rubber door seal
I also have this problem on my 98 S70s. From what I can tell these seals aren't glued on from the factory. All I do is work the seal back up under the trim on the inside of the window and that's usually good for a couple of months before it drops down again. So far I haven't seen the need to glue it on....
I finally did something about my door seals. The silicone I used wasn't anything special, although I did make sure that it was a waterproof silicone and I preferred clear. Basically, I just peeled out the part of the seal that was giving me trouble, plus a little more, and applied the silicone in the groove of the rubber that makes contact, put it back on, and then held it there for a minute. I checked on it a couple more times that night, and it was all good. It hasn't been too long since then, but it seems to be doing fine.
850forum
09-08-2012 02:21 AM
