S70 2,0T vs 850 T5
Hello
I have a Volvo S70 2,0T 132kW. My questions is - what's the difference between my car and a Volvo 850 T5 (2,0 155kW)? If you look under the hood they look the same.Does the S70 have adownforced T5 engine. What are the differences: the turbo, the ECU settings, the turbo nozzles, etc. (I put the subject under V70 by mistake at first) |
RE: S70 2,0T vs 850 T5
1. The T5 is an HPT and your car is an LPT
HPT = High Pressure Turbo LPT = Low Pressure Turbo 2. That means your turbos are different. Meaning the HPT (T5) has a bigger turbo and your LPT (2.0T) has a smaller turbo. 3. Your ECU's are not the same either. 4. I don't know what you mean by turbo nozzels. |
But the turbos are compatible? aren't they? The HPT fits my car aswell.
Is the ECU difference only in the settings or are they completely different? |
