Trick to get the ABS light off
I found this web site that shows a way to get the ABS light off and keep it off. I hope it helps someone else out. I tried it and it works, I used a piece of plastic that was in a wedge shape and it worked like a charm. Good luck
Volvo S70-V70 Abs Module repair | Car Instructions |
Wow, that is something else. Not sure if that pressure between the 2 will ever damage another part but that is a quick Jerry rig fix.
Great stuff,even if temporary that,s a good fix.
Thanks!
I joined the forum for the link you gave. I love the car but the repair costs, ouch. Thanks again.
I found that a while back - it works for a while, not forever unfortunately.
Take the module off, contact BBA- Reman, and have them rebuild it. Costs about $60, and they guarantee it for life. Yeah, the shim- it fix works for a little while, but eventually, the connections wear further and the problem will come back again.
I checked the link and its good to get ABS light off, i tried too and it worked for me, so good stuff and if u have some other stuffs like this post here....
So the theory is the vibrations from ABS pump are causing module malfunctions?
Originally Posted by Typhoon
(Post 275932)
| All times are GMT -5. The time now is 07:16 AM. |
